Old Jul 20, 2012 | 10:36 AM
GraphiteGhost
Default Re: Oil filters $8.50 each if u hurry!
Originally Posted by Mrmiata
They are plenty sturdy! And you just tighten the screws on the side till you have fair drag against it moving.
There is a hole already in the mirror where you can insert an allen wrench and turn the mirror to remove from it's windshield base - that's the one you tap .. just twist it in a circular direction (un screw it basically about a 1/4 turn or so). If you have the autodimming, there is enough slack in the wires where it goes back into the homelink wiring to lower it and get it tapped. You'll need to pull the dome light assembly to pull the slack back up after / while putting the mirror in place.
OK, they took my counter-counter offer of $3.35 and it has free shipping. So you tap the mirror removal hole then how do you remove ithe mirror after you remount it? Maybe just unscrew the ballpost for the mount? It looks pretty easy and it'll also keep the windshield clean too!
