Old Jul 25, 2012 | 02:44 PM
ala_xfire
Default Re: Did the $3.35 Mirror CCTV/Radar Detector Mount Mod!
Mr M, I barely screwed the ball post into the mirror base because the more you screw it in, the higher up the other end ends up. I needed as much hanging down as possible. Also, the post sitting in too far into the mirror base was hitting the mirror mount on the windshield when reattached. The way mine ended up allowed it to be as low as it could get without some sort of extension on the radar bracket. I might look at adding some type of extension in the near future so I can use the mirror dimming lever. BTW, on the trip out to the base and back, the detector didn't move/bounce any at all. Very tight and firm/solid.
If you install an auto-dimming mirror, there is no bottom lever to fool with .....
Just sayin
