Re: Driver's Dash Access
LOWER I/P PANEL LEFT
1. Remove the driver knee blocker airbag.
2. Remove the air nozzle and the screw behind the nozzle.
3. Remove the screw (3) attaching the cover under the steering column then remove the cover (2).
4. Remove the fuse panel cover.
5. Remove the screws (1) attaching the lower instrument cover (5) to the illumination control module (4) and the side of the instrument panel to the support bar (6). Remove the screw at the top of lower cover to cluster cover.
6. Remove the illumination control module (7).
7. Pull the lower instrument cover (2) off of the cluster cover.
8. Remove the screw (2) attaching the hood latch release handle bezel to the lower instrument panel and then guide the handle through the lower cover (1).
9. Separate the lower panel (2) from the cluster cover (1) and then remove the lower instrument panel.
