waldig
If the wye area were chilled you would gain. I have not figgured out how to cool post SC where the temps are the highest and cooling is most beneficial, not to mention easiest. Problem is that there is no real physical access or room to add contraptions but you know I have tried ALL MANNER of cooling. Woody
EUREKA!!!!!
I am going to be using
Aluminum Intake Reducer 3.5" OD to 3" OD: Intake Hoses, IntakeTubing, and Intake Clamps
to connect to
Black Rubber Intake Tee 3" ID: Intake Hoses, IntakeTubing, and Intake Clamps
which connects to my intake system
connecting this (BULB AND LEGS ONLY) inside of the 3.5 to 3" aluminum reducer (closest thing to throttle body) via drilled holes and weld
CryO2 Air Intake 080110 | Purchase DEI, CryO2, Ny-Trex, Boom Mat & SPA Turbo Products | Design Engineering, Inc. - Thermal Performance Products
with the pointy end of the tear drop pointing towards the "Tee Split Intersection" to increase air flow into the throttle body...
I will eventually add
http://www.designengineering.com/cat...genic-fuel-bar
to cool the fuel (might as well get the most use out of my c02 as possible!!!
Later on I will also be connecting the "Out" port of the bulb to this to cool the heat exchanger
http://www.designengineering.com/cat...cooler-sprayer
NOTE: This component must always be the last in the CryO2 system as it vents the liquid CO2 charge.
BUT, it will be also sprayed with
http://www.designengineering.com/cat...er-sprayer-kit
so the water sprayed on the heat exchanger will be further cooled by the liquid CO2 sprayed on the water, on the heat exchanger....
But first I need to get a bigger supercooler and possibly a 62MM SC Pully.
In the end, it should look something like this (minus the second intake cooler and adding the water sprayer)
http://www.designengineering.com/sit...main-large.jpg
I think this all may just work.... Will take me 2-3 months to get everything ordered and installed but stay tuned.
Just ordered the first step,
for 1/2 the price on the Cry02 SITE!!!
There are 2 left if anyone else wants to buy one , just make sure you click the lower price at the bottom where it say's (2 New - 219.99)
