Thread: Crossfire Keys
Old Jul 31, 2012 | 02:02 PM
Dal's Avatar
Dal
Thumbs up Re: Crossfire Keys
Yes it should, do you have the instructions for programming it? I'll see if I can find them real quick.
Edit: Found it
Originally Posted by Shawnkey
This is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
Insert the key into the ignition switch.
Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
Shawn
Awesome, thats just saved me a few quid
