Old Jul 31, 2012 | 03:36 PM
JHM2K's Avatar
JHM2K
Default Re: BEGi Turbo Kit information/discussion thread
Originally Posted by tighed1 (on behalf of Corky)
Has the CrossFire group ever mentioned problems with ground clearance?
Yes, as I discussed with him that many of the Crossfires that will be utilizing this kit have a lowered suspension... And even at OE height, the kit needs to be as "tucked" as possible. This concern was also mentioned in the first thread on numerous occasions.
We are adding one inch to the bottom over about 70% of the wheel base.
The low spot is about 1.4 down but is between the front wheels. This latter piece at least goes up when the front wheels do.
Is the lowest piece attached to the suspension? Otherwise, when the shocks compress, the piece should actually be even lower to the ground...
This should get interesting.
