Old Aug 2, 2012 | 08:38 AM
pizzaguy
Default Re: Oil warning light / odometer missing?
Originally Posted by arctct
The FSS reset worked after disconnecting the battery for a while. THANKS MRMIATA !! The odometer is back from holiday. The red oil warning light remains to be a mystery however, and comes on intermittently. I can live with that for the moment. Thanks forum members !
How much oil are they putting in? If the oil is overfilled, you will get a high oil level alarm (mostly in curves or going downhill - at least, that is what mine did).
I only put in 8 quarts (not 8 1/2) when changing oil (per "Danimal") and don't get the light anymore.
Once you learn to do the FSS reset, it is easy and there is no reason to disconnect the battery. You just have to keep trying and follow the procedure in the manual. It is a known frustration to those trying to do it the first time - they make it hard so you can't accidentally reset it.
The Throttle response reset is easy if you follow Valky's post EXACTLY. It really IS simple to do.
