Thread: Coolant leak
Old Aug 5, 2012 | 11:55 AM
onehundred80
Default Re: Coolant leak
I was going to suggest you just pull off the passenger side manifold to verify if your IC is bad. It would be obvious, green coating in there. Now with a spot on the floor I'm not so sure. Good luck!
The drops are water, I managed to spot where it is coming from. It is coming from a small slit rubber drain in the cowl, there must be some crap over the drain and it is just dripping out slowly. I washed it yesterday and it rained when I took the car out last night. Wash the car and the drought will end.
Back to square one, so I will remove the IM and look for signs.
This is not going to be cured easily. $403 for an intercooler does that seem about right from http://moparonlineparts.com/repair-p...r/intercooler/ ?
