Old Aug 8, 2012 | 09:19 AM
Mrmiata's Avatar
Mrmiata
Default Re: Replace the Crankshaft Position Sensor now??
Originally Posted by G.Seabrooks
I replaced the CPS but I am still having cranking problems. Could it possibly be the relay control module? I need help and my mechanic needs help. I have an 04 Crossfire.
If the engine spins, your rcm is working. Bosch brand CPS I hope.. Has he checked fuel pressure? Any cel codes showing? When my cps became the issue (04 model) I hooked up my OBD scanner and had the cps code so I knew why it wasn't starting.
