Old Aug 11, 2012 | 09:46 PM
pizzaguy
Default Re: Secondary codes not going away to get the car smog
CEL - check engine light - if it isn't on, you don't have a problem, go get the smog check.
The RCM is a common failure item - you can just resolder the connections on it and you are usually ok.
Bet you wish you'd known that $600 ago, huh? We even have a loaner module you can trade tighd1 with for $10.
