Old Aug 11, 2012 | 10:49 PM
pizzaguy
Default Re: Remove Lower Grille
Use a flatblade screwdriver and take 'em off!
There is a hole at the outer end of each one and you use a screwdriver to push the tab over while pulling out on the grill. It's easy once you "get it" and you can (well, I can) do it all with one hand - I put the driver in, press over on it, and pull at the same time.
