Old Aug 13, 2012 | 04:36 PM
trevorradman's Avatar
trevorradman
Default Re: Dyno Number thread (graphs+mods info+and more)
Originally Posted by JesseJamessrt6
I had no idea what corrected vs uncorrected meant so I read up here Equations: Dyno Correction Factor and Relative Horsepower south texas is far from Detroit...
Newbie questions here- How do I plan ahead with a dyno to get a digital dynograph? Does it just matter on the setup of the dyno and weather they offer a digital file? Do you bring a thumb drive or do they e-mail it to you? I have the same question for the digital time slips from a drag strip too. Also, can anyone explain what gears the most accurate dyno run's are and what is typical?
Find a comany that does 3 Dyno pulls with Air/Fuel for ~$100. Setup an appointment. They will do a printout and or email you the graphs. You want them to pull in 4th gear, closest to 1:1 ratio, should be over 130 MPH on the graph, else they got wrong gear(happens on automatics that shift when they want). They will ask how high they can rev, I let them bounce it off the limiter.
