Old Aug 13, 2012 | 04:51 PM
GraphiteGhost
Default Re: Turn Signal Assembiy, Highbeam switch
Originally Posted by Bolisg
Driving to work this morning I placed my highbeams on, and no luck they did not turn on, but if I pulled the turn signal forward they would work. Am I looking at a replacement or is there something I could do, cleaning or checking some other place look?
Sorry your having high beam troubles. Did you check fuses 3 and 5 in the light fuse block? Those fuses are accessable when you open your drivers door, go to the dash panel there left of the steering wheel. The panel opens with a coin, there will be a bunch of interior fuses. Hope that is your problem!
