Old Aug 16, 2012 | 08:21 AM
ala_xfire
Default Re: Convertible Top Sensor Beep
The symptoms described point to the top locked sensor switch that is located in the header bar.
This switch tells the electronics to lower the windows when the top is unlatched, and also tells the electronics that your are allowed to exceed 9 MPH without alarm when it senses that the top is locked down.
Pizza, you are welcome to correct me if I am wrong, I defer to you as the top expert ...
