Convertible Top Sensor Beep
Old Oct 23, 2018 | 12:56 PM
Vojc007's Avatar
Default Re: Convertible Top Sensor Beep
It is there
Old Oct 23, 2018 | 05:09 PM
Vojc007's Avatar
Indeed it is there
Old Oct 24, 2018 | 01:35 AM
Vojc007's Avatar
I have another problem Zeracer.
I must change right stop light bulb but I can't find access to the bulb.
Can you help me ?
Old Oct 24, 2018 | 07:05 AM
Can you help me ?
Raise the top and stop at point that top is up and tonneau is still upright.
You can then reach in and access all the bulbs.
Old Oct 24, 2018 | 06:13 PM
Just remember you only have 10 minutes before the pressure goes out of the system and it starts to close on you. You must move the top a bit every nine minutes or so to keep pressure in the system. Have the replacement bulb there and just remove one and install the other. It is a bit of a reach inside. Also be sure you know which bulb you want to replace before starting.
Old Oct 24, 2018 | 07:06 PM
Larry Hitze's Avatar
I changed the stop and turn bulbs on my roadster by just removing the panels on the rear of the trunk and sides. I was very easy to do.
Old Oct 24, 2018 | 08:20 PM
KeithTexas's Avatar
I did the same thing. No problem.
Old Aug 21, 2019 | 02:28 AM
Vojc007's Avatar
Hello Zeracer,
last year I put back this striker pad but the problem is still open.
Everything is OK when I lower the top. But when I latch D ring latch handle the sound beeping is starting and the LED don't turn off but start blinking. For a minute or two. Then stop and after about 10 or 15 minutes of driving beeping and blinking starting again.
I don't know how to check sensor which indicates that D-ring latch handle is latshed.
Old Aug 21, 2019 | 08:33 AM
Hello Zeracer,
There is one way to test that sensor.
1) Start engine.
2) Put top up all the way, put windows up all the way.
3) Wait for beeping to stop if it will stop; move car, drive it, if that makes beeping stop.
4) Keep engine running, stop moving car.
5) Turn D handle - if windows go down, sensor is OK.
If the windows do NOT go down, you found your problem- the sensor is bad.
If the sensor tests OK, then some other sensor or item is preventing the top module from thinking that the top is up all the way and the cycle is complete.
Old Aug 22, 2019 | 06:52 AM
Vojc007's Avatar
Latch D handle or not ?
Latch or unlatch D handle ?
Old Aug 22, 2019 | 11:36 AM
Yes, you can't "put top up all the way" wihtout latching the D handle.
Turn and unlatch, press top up and away from frame.
Old Sep 18, 2019 | 02:25 AM
Vojc007's Avatar
1.
Pizzaguy
Point 5. - the windows go down so the sensor must be OK.
I drove the car to the mechanic to solve this problem.
The mechanic didn't solve the problem but open a new one.
The problem is:
I unlatch the top and I put it up, the top comes up to the stopping point and doesn't stay at that point. The top just falls down.
If I want to complete the operation I must hold the top with my hand at the stopping point and push the button to continue the process electrically. It seems it is a mechanical problem. What holds the top at the stopping point (100 to 150 mm over the windshield)?
Old Sep 18, 2019 | 03:21 AM
There are 2 nylon cords with springs, one on either side that do that.
Old Sep 18, 2019 | 05:13 AM
Vojc007's Avatar
Thanks
Old Sep 18, 2019 | 05:27 AM
Vojc007's Avatar
Where cord and springs can be seen?
Old Sep 18, 2019 | 07:42 AM
KeithTexas's Avatar
If I remember right, you can get a glimpse of the location of the cord while watching Marc's video on replacing the top.
Convertible Top Replacement Video
I have the same problem. I have to hold the top with one hand while I initiate the raising of the top and then I have to catch it with one hand while I'm lowering the top. Not a big deal. I'll someday tackle opening up the top to get to the cord.
Old Sep 18, 2019 | 08:56 AM
1.
I don't see how the guy could have done THAT, you have an electrical issue, if he started messing with the physical aspects of the top, he's borderline retarded.
He is excused for not understanding electrical or electronic troubleshooting - almost NO 'techs', 'mechanics' or similar do. But if he really did cause this, jeeeeezzzzzzzzzzzzzzzzzzz.....
See why I fix stuff myself - or go to a Crossfire tech day?
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
ringpsanner59
Mar 22, 2016 03:44 AM
55chevy
Sep 8, 2015 10:32 PM
d907ie
Aug 31, 2015 08:56 PM
