Old Aug 21, 2019 | 08:33 AM
pizzaguy
Default Re: Convertible Top Sensor Beep
Originally Posted by Vojc007
Hello Zeracer,
last year I put back this striker pad but the problem is still open.
Everything is OK when I lower the top. But when I latch D ring latch handle the sound beeping is starting and the LED don't turn off but start blinking. For a minute or two. Then stop and after about 10 or 15 minutes of driving beeping and blinking starting again.
I don't know how to check sensor which indicates that D-ring latch handle is latshed.
There is one way to test that sensor.
1) Start engine.
2) Put top up all the way, put windows up all the way.
3) Wait for beeping to stop if it will stop; move car, drive it, if that makes beeping stop.
4) Keep engine running, stop moving car.
5) Turn D handle - if windows go down, sensor is OK.
If the windows do NOT go down, you found your problem- the sensor is bad.
If the sensor tests OK, then some other sensor or item is preventing the top module from thinking that the top is up all the way and the cycle is complete.
