Old Jan 26, 2006 | 05:43 PM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: Problems Starting...
Originally Posted by jpristel
About 1 out of every 15 times I try to start my crossfire, it won't start (even if I keep the key in the start position for 30 seconds). I can hear the engine turning over, however I don't believe the engine is flooding because if I remove the key and immediately try to start it again, the car will literally start in under 2 secs.
Any ideas?
Thanks.
sounds like an ecu glitch of some sort. when you remove the key and place it back into the ignition... it resets the cars ecu. hence the reason for starting the 2nd time around.
this would be my guess.
the crossfire has an electronic ignition with f.i. it wouldn't make sense to be flooding such as a carbureted car would do. but i'm no certified mechanic.
time to head to the dealer for a diagnostic.
