Old Aug 21, 2012 | 07:35 PM
  #50 (permalink)
arejohn's Avatar
arejohn
Default Re: Oil. Why should I use
Originally Posted by +fireamx
OK, so now you're telling me the Viscosity actually goes down as the oil heats up too?
Could we be confusing "flow characteristics" with viscosity?
And I thought it was magic.
a SAE 30 motor oil is the same viscosity as a 10w-30 or 5W-30 at 210° (100° C). The difference is when the viscosity is tested at a much colder temperature. For example, a 5W-30 motor oil performs like a SAE 5 motor oil would perform at the cold temperature specified, but still has the SAE 30 viscosity at 210° F (100° C) which is engine operating temperature. This allows the engine to get quick oil flow when it is started cold verses dry running until lubricant either warms up sufficiently or is finally forced through the engine oil system. The advantages of a low W viscosity number is obvious. The quicker the oil flows cold, the less dry running. Less dry running means much less engine wear.
Still sounds like magic.
.And i thought it flowed like a 0 and lubed like a 30
5u7
