Old Aug 22, 2012 | 03:02 PM
rcompart's Avatar
rcompart
Default Re: Controler for Anti-Lock Brakes
Originally Posted by KipKaplan
Got the error code BAS/ESP on the dashboard. Chrysler dealer said the "Controler for the Anti-Lock Brackes" had failed, and needed to be replaced. Found another one, had it put in, and still get the error code. Anybody had a similar issue with this?
Thanks, KipKaplan
Is it just the BAS/ESP light or are you also getting ABS light as well? If only one light, there are pretty much only three things that can have something wrong... ABS controller (you swapped it out so pretty good chance that's not it) Steering angle sensor or Yaw/roll rate sensor. Hope this helps but yes, I experienced this regularly with my old car... though mine was self induced.
