Old Aug 24, 2012 | 01:13 PM
  #148 (permalink)
onehundred80
Default Re: 62mm SRT6 Pulley Available Now
Originally Posted by rcompart
Actually, tubes are tremendously strong when end loaded and actually crush with much more effort than a similar square or other broken straight plane support. This is why we have round supports for bridges and the like. What I think you're trying to say is the tensile strength of a tube isn't as great as that of it's solid core variant. This would be correct. Just for argument sake though, if I had an M6 solid and an M12 hollow, the M12 would stretch less and fail with significantly greater force. That is unless it's walls were only as thick as tin foil.
Tremendously strong..... yes, but they bulge out, not in, as out is the stress relieving direction. In some structures the bulging has no effect on use and is ignored.
Out of interest the ID of the hollow M12 would be 10.4mm to have the same cross sectional area.
This was already taken into account and is why the bearing spacer is made from aluminum and not stainless.
Aluminum is often used for ease of machining and cheapness.There should be no drawbacks in this case though.
