Re: TIRE PRESSURE MONITOR - "HIGH PSI"
The 27 psi in the passenger rear tire should definitely trigger the light. You have 3 tires under inflated but the passenger rear was the problem (most likely). While over-inflation isn't good either, I don't think it caused the monitor light.
