TIRE PRESSURE MONITOR - "HIGH PSI"
Old Feb 17, 2006 | 11:21 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: TIRE PRESSURE MONITOR - "HIGH PSI"
qtrfoil...
you are correct the sensors are programmed to the car... any replacements sensors will trigger the dash light (system isn't recognizing it).
unfortunately...a dealer fix only.
Old Feb 18, 2006 | 07:04 AM
typhoon55's Avatar
If the dealer replaced your tire & valve, they would have recalibrated the tpm. Not sure from your post if that is the case. It is a dealer issue although I have heard some tire chains can do it.
Old Feb 18, 2006 | 03:03 PM
patpur's Avatar
Senior Member/Moderator
Don't know if this will help but I've put the car in the garage at night and gone out in the morning after a substantial temperature drop and the light comes on. I think it was your low tire too but maybe the air temp caused a drop in tire pressure in that tire that tripped the sensor?
Just a thought.
Pat
Old Jun 23, 2007 | 05:27 PM
Bostonsrt6's Avatar
Hey Guys I am running new tires with rims on my car 20x10 in the rear with 285's and 19x8.5 in the front with 235's. My PSI on each tire is 38 PSI and the light is still on. Do you think a sensor could have been damaged? The guy at the wheel shop said I have to program the sensor to the car. Does that make sense? Could he just use a mercedes OEM sensor?
Old Jun 23, 2007 | 06:07 PM
Maxwell's Avatar
You need to go to the dealer and have them recalibrate the pressure sensors.
I have a stock set up, and my pressure light has been on for months. Running the correct pressure and the light wouldn't go out. I took the car in yesterday and they some how reset the sensors?
Kodebuster
Nov 5, 2020 04:06 PM
Danyuhl
Nov 2, 2019 05:18 PM
velociabstract
16
Oct 12, 2015 10:56 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
axnguyen
Jul 21, 2015 11:41 AM
