Old Sep 1, 2012 | 12:38 PM
  #949 (permalink)
amx1397
Originally Posted by Beaner
Why anyone does not just put it in the corner on the passenger sidew of the car I have no idea. There should be a small enough battery to fit on the bottom. Height should not matter in this situation. There is a vent like described by 180, there is a hole on the bottom for drainage if fluid was ever to get in there (hose from gas filling area drains through, there is a place to either hook on or bolt on a strap...
Ohh, And I painted my airboxes and engine cover this morning! Remember to turn the aircompressor on before you start... I'm a newbie. Another coat is needed on 1 part
no one puts the batt on the right side because the air pump and the Electronics that operate the locks along with the vacuum that's in that corner if you put a battery of their the fumes would prove your electronics and your pump, better to stay on the left side(drivers side.) that's why.
