Old Sep 3, 2012 | 06:07 PM
bri3d's Avatar
bri3d
Default Re: Outside Temperature Display Reading Extremely High
Per the service manual there's more than just the raw sensor reading factored into the "outside temperature" that gets displayed on your dashboard.
Page 8J-71 of the '04 service manual has this to say:
To display the outside ambient air temperature requires the fol-
lowing:
• outside air temperature
• wheel speed signal
• engine run time
• engine coolant temperature
The outside ambient air temperature is determined by the out-
side ambient air temperature sensor. The temperature sensor
is installed at the front left of the vehicle under the bumper fas-
cia and is connected to the IC. The wheel speed signal,
engine run time, and engine coolant temperature are deter-
mined internally by the IC. Since the outside ambient air tem-
perature display depends on the wheel speed, engine run
time, and engine coolant temperature, temperatures (influ-
enced by the heat generated by the engine, for example) are
not updated when the vehicle is stationary or moving slowly.
• When the ignition is in the ON position and the engine
coolant temperature < 60°C (140°F), the current air tem-
perature is always stored and displayed.
• When the ignition is in the OFF position and the engine coolant temperature < 60°C (140°F), the air tem-
perature last measured is stored and displayed.
• When the ignition is in the ON position and the engine coolant temperature < 60°C (140°F), the stored air
temperature is displayed.
• At vehicle speeds of 19–60 km/h (12-37 MPH), outside air temperatures are displayed after a delay of
approximately 5 minutes.
• At vehicle speeds over 60 km/h (37 MPH), outside air temperatures are displayed after a delay of approximately 2 minutes.
