Old Sep 4, 2012 | 11:14 PM
rcompart's Avatar
rcompart
Default Re: Complete Brembo Red 4-Piston Front and Rear AMG Caliper and 345mm/330mm Rotor Upg
Originally Posted by 04Fire
Rudy,
This sounds like a hell of a setup... but of course I have a question. When the calipers are bolted up are the pistons setup on the proper orientation (small to big for forward rotation)? I've been reading up on all the different calipers that can bolt up to our cars but, don't believe I've seen anyone with the pistons oriented correctly.
Hope that made sense.
I'm splitting the calipers and plan on switching them around so both the pistons and bleeders are oriented correctly for the Crossfire since they use leading vs trailing calipers.
Originally Posted by turbomar
Those are the C class calipers, right? I am looking for used rear calipers. BTW. I did convert my front calipers to be used in the leading position
https://www.crossfireforum.org/forum...upgrade-7.html
See post #136
Yes, the 4-piston fronts are C32 and the 4-piston rears are S55.
Originally Posted by xfireon20z
any pictures?
I don't have any pictures of the calipers now but I will get some as I start going through them. Below are some pictures of the 6/4 setup I am doing for my car and the same will be done with these. The rears for sale look the same as the rears in these pictures.
This is how they looked prior to being refinished and sanded smooth. Notice the pits and scratches in the face.
Here they are masked off and ready for coating. The faces have been refinished and sanded and are all smooth and the pits and scratches have disappeared.
Here they are coated and ready for the pistons to be reinstalled with the new seals, dust boots and caliper hardware.
