Re: Disabling Seatbelt Chime/Alarm WITHOUT cutting any wires!
Here ya go.. guess twice or three times in the same thread won't hurt.. LOL..
DISABLING THE SEATBELT WARNING CHIME!
From our friend Thomas Whyle... (Credit given)
The correct procedure for the Crossfire is as follows:
1)Turn key to ON/START - within 60 seconds, turn ignition OFF and fasten the driver seat belt.
2)Start engine and wait for the seat belt light to turn off.
3)Within 60 seconds unbuckle/re buckle the seat belt 3 times - ending with buckled, you will hear a single chime (sometimes this verification chime is slightly different just the same it works to disable the chime).
This confirms you have turned the repeater chimes off. Repeat the sequence or disconnect the battery to restore the reminder function."
Disconnecting the battery will reset the chime and you'll have to do it again!
