Old Jan 31, 2006 | 10:18 PM
typhoon55's Avatar
typhoon55
Default Re: TIRE PRESSURE MONITOR - "HIGH PSI"
Originally Posted by CrossfireLTD
No...could be any combination of loss pressure per tire. Example; 1 tire with a 2 lb. loss another with a 1 lb. loss another with a 3 lb. loss and the last tire with a 2 lb. loss, the total will equal 8 lbs. and the TPMS will trigger. Now on the other hand if you have 3 or all 4 tires that are low and do not equal 8 lbs. or 25% loss the TPMS WILL NOT trigger. That is why it is important to check tire pressure weekly or bi-weekly.
I understand yet is the benchmark for the 25% - 26 lb?
In addition, as I understand , any tire with more than 26 lbs would not affect the 25%.
