Old Sep 5, 2012 | 09:43 PM
onehundred80
Default Re: Replacing engine coolant using a GREEN method
Originally Posted by waldig
Simple, flush the tanks and engine with compressed air, use a shop vac or air hose with limited pressure. The air will carry off more of the fluid and RINSE low spots without scaring the worms. Another woody thought.......Taaaa Daaaaa
Enjoy,
OBTW you could also use the rinse fluid for the water make up if you were to use distilled water, ?.
That's a good idea, distilled water is cheap enough. I can dump it down the drain rather than let it go into the storm sewer which would kill the fishes and leave me with healthy worms but nothing to catch.
Three gallons of distilled water would do the trick, about half to be dumped and the rest as makeup fluid.
Problem solved.
You're not just a pretty face Woody. LOL
