Old Feb 1, 2006 | 09:28 AM
danimal's Avatar
danimal
Default Re: TIRE PRESSURE MONITOR - "HIGH PSI"
Originally Posted by midnightman
Now I'm totally confused....
Am I wrong in thinking that most of you all own Michelin Pilot Sport tires? And am I wrong in thinking that the recommended pressure as suggested by the label inside the driver's door is 32 psi on the fronts and 33 psi on the rears?
I don't understand it either...
It is no wonder that they are having so many problems with the system. If the recommended pressure is used, and it that pressure is checked often, things work as designed (for the most part).
