Old Sep 10, 2012 | 12:51 PM
RL67037's Avatar
RL67037
Default Re: Trying to Disable a Speaker. HELP!
Originally Posted by Kolme
Ok, while in the process of getting a replacement sub for the rear... sigh which is really not going great... I realllyyy want to disable that damn sub... (It is the driver side rear sub)...
So what i tried was going behind the headunit (i have an aftermarket one which is easy to get behind).. And cut the green wire which in the wiring diagrams shows as being the Left Rear Speaker (aka the sub)... Ok So i cut the wire.. anddd... NOTHING! nothing happened at all! to any of the speakers!!! I double checked all of them and it was as if nothing had been cut...
So plzzzzz, someone help me disable this sub... I would REALLY rather not struggle with the clips, the hex screws, the carpet, etc etc to get to the sub... So if you can help me get this thing disabled w/o doing that... I will appreciate it SOOO MUCH.
Kolme
I don't think you will be able to disable it from behind the head unit because the factory output of the head unit is "Left" and "Right" and doesn't discern between "Front" and "Back" or "Door" and "Sub". In order to get to where the door speaker and sub channels are separated, you might have to do that at the output of the factory amp, which is located under the passenger footrest area. Not real sure how it's separated, will have to look at the wire diagram. As far as cutting the "green" wire, was that a green wire in the factory harness or from the head unit or in the adapter harness?
Will do some more digging.
RL
