Old Sep 10, 2012 | 01:17 PM
RL67037's Avatar
RL67037
Default Re: Trying to Disable a Speaker. HELP!
Originally Posted by Kolme
Welllll, It was a green wire attached to the unit so I suppose it was a part of the adapter harness.. I actually didnt do the install, a fellow who used to come on these threads (he sold the best looking SRT6 besides maybe Chads like a yr ago) did it. I can easily splice and rewire them (I always leave slack because I know I'll do something dumb).
I did look for a wiring diagram for the amp but didnt find it, although im 100% postive that ive seen it before... lemme know if you have any suggestions RL!
Thanks
OK - Well, here's the diagram for the audio system showing the factory radio, factory amp, speakers and so on. There are only for outputs from the radio that go to the amp which would be your left and right speaker wires (2 wires per side). So, that tells me there is no way to disable the subs from the back side of the head unit UNLESS the dude that installed the head unit ran separate wiring to control the subs like what is mentioned n this thread:
https://www.crossfireforum.org/forum...amplifier.html
If that mod has not been done, then you will need to go to the amp (under the passenger footrest) and disconnect the connector for the left rear sub (pins 6, 16, 12 & 4).
Hope this helps!!
RL
EDIT: And I would re-connect that green wire. Not sure what it's connected to, but I would bet it could be important.
File Type: pdf
