Old Sep 12, 2012 | 09:55 PM
GraphiteGhost
Default Re: Secondary Injection Conundrum
Originally Posted by liberty1
Through the P410 code again. Sure enough contacts on relay are black again. This will be the third time I will have to clean the contacts. Seems to last about four months. Is there anything that can be applied to the contacts after cleaning to help stop this from reacuring?
Hi! The relay contacts may be too damaged to clean properly, and/or the load going through them is way above the contact tolerances. I would see if a swap is in order (not the typical swap, one with clean contacts so yours can be repaired and put back into use) I would think this swap would cost some more to cover the costs associated with a relay and such. This new module would only treat the irrepairable contacts, not a high current issue)
