danielcool
I'm new to the forum. I have a 2005 Xfire covertable, blue, 16,600 miles. Having problems with lowering and raiising the top. Very surprized to see there isa TSB on the top rear window adhesive. Prety sure i qualify for the new top - its a2005 and has less than 100K miles.
The top won't go down nor will the rear of the top latch down. I have made sure the top compartment in the trunk is in the correct position, rear deck lid is closed, windows are down and there is power. The motor hums for about 5 seconds then quits with no up or down action. Thanks
There is a whole thread on top problems, but I would suspect that you have a switch over the passenger side window that is bad, just guessing from the little information you provided. Do a search for the thread...I have a video on manually raising/lowering the top...
