Thread: Door Chime
Old Sep 27, 2012 | 12:03 PM
pizzaguy
Default Re: Door Chime
Maybe you damaged the micro switch that tells the BCM there is a key inserted. Lucky you, I hate that chime.
Ed: I am only marginally mechanically competent, and I did the fix in 90 minutes. IT's not bad at all, just follow the instructions in the tutorial here and try to attempt the job when others are going to be online in case you need help!
I found a medium size pair of vice grips to be essential in working the assembly out of place and back into place after the mod. I had to go buy a pair during the fix, even!
It's really not that bad, usually, if you attempt the repair BEFORE it locks up and you need to drill that damn pin out!
