Old Feb 5, 2006 | 03:37 AM
uclaXfire's Avatar
uclaXfire
Default Re: electric supercharger
Originally Posted by FirebaseD
why don't you just remove the fog lamps and run your air inlet hoses down into the holes. Duct the air into your engines that way.
I would, did that with my '92 stang, it had a 6" hole for the foglight, but the fog light hole is too small on the crossfire. To get any sort of positive pressure to build, you need to start with a larger than 3" (manifold size) and taper down, to get an good increase in pressure (Bernoulli principle).
But if you find a frontal cross section area larger than 3" then you are in business.
chung
