Old Oct 3, 2012 | 12:01 PM
  #124 (permalink)
onehundred80
Default Re: p0410 secondary air injection system malfunction solution?
Originally Posted by wraith13
Has anyone soldered in a new relay yet???
Not that I have heard, it should not be too hard if you are adept with a soldering iron and know how to use a desoldering tape.
https://www.crossfireforum.org/forum...tml#post550548
Once the contacts are burnt they will continue to get damaged from the arcing. When refinishing the contacts the surface should be as good as they were before. If the surface is just plated then they are probably burnt through the plating and probably ruined.
