AlexParra
robby, you must know a bit about mechanic...
I recently had new tires put it and balancing of course. But the mechanic didn't do the aligning since he diagnosed the following:
Lower ball joints $95 each
Upper control arm $45 each
front shocks $95 each
Rear shocks $85 each
Left front wheel bearing $27
Parts $567
Labor $506
Total $1,073
At least I know what's causing the noise now!
You should get the ball joints, upper control arm and bearing fixed asap if you need them. If one of them break you could end up having an accident.
