Old Oct 9, 2012 | 08:14 PM
oledoc2u
Default Re: Can I fight this ticket?
I can only imagine, with you being the special people person that you are, that you didn't **** the officer off. Did you stop in the lane behind the officer or swing behind directly on to the off ramp? Legally you are suppose to pause in each lane when changing lanes.
Most people don't move over for their exit soon enough. They want to wait until the last second then find a hole or try to make a hole to get over.... The turn signal is nice, but it won't buy you a spot. WE have a section of road like that here locally on a local interstate. That jurisdiction sets there and writes improper lane change citations all day long until the people using that section of road learn to get over well in advance to exit rather that run all the way up to the exit and try to crowd their way in. This might not be the case in your situation, but if it is, you will lose...if it isn't, you have a right to your day in court....good luck...
I might add one other circumstance. If you exited from the center lane to the exit...that is considered an illegal lane change...
