Originally Posted by Cyril Baldwin
Actually if you check out
www.greenfilters.com they already use the same principle of the tornado incorporated with their $300 each twister green filter for crossfires.
If you have high - end home theater system, hyper voltage system is the same principle as the Monster Cable Voltage regulator / line conditioner and high - end gold cables. They make the sound much more cleaner and crispier and the colors much better than regular cables. With a 1,000 watts subs in my trunk, although I have a separate battery for my audio system, I bet it still takes off some power in my crossfire.
Visit me at:
http://www.cardomain.com/ride/2053478
The purpose behind monster cable it not necessarily about power it is about getting a better frequency response. Higher frequencies have a tendency to travel on the outer surface of a wire (Skin Effect) This is why the cables are huge, so you have more travel area for the frequency/voltage. This is basically used to enhance analog type signals such as speaker wires. I think that the Hyper Voltage system is probably nothing more than a large capacitor, this will store a reserve of voltage and clamp any unwanted frequency noise.
