boocher13
Recently on start up with the engine stone cold the coolant light comes on and the fan is running full blast. Although I have an extended warranty I want to avoid the Stealership as much as possible. So I'm thinking its either a relay or sensor because once the car comes up to temperature the light goes out and from then on it cycles on and off as intended. Has anyone had any experience with this issue and where can I find a schematic showing the proper relay and sensor I need to be testing. Thanks in advance peeps.
