onehundred80
My guess for what it's worth is that there is a problem with the SKREEM module or the halo around the ignition keyhole.
If the wire from the ignition switch halo ring is disconnected the car will not start.
If the SKREEM module is broken the car will not start.
I think you have stated that you have tried more than one key, so the key chips are presumably OK.
I am not sure if these problems set a code though.
Exactly what I was thinking when I asked if the key switch had ever been removed or replaced. It was Howard IBLUBYU that had the wire come off his halo after the repair.
