Old Oct 14, 2012 | 08:30 PM
onehundred80
Default Re: Help! My Crossfire Roadster won't start!
I believe more accurately, the SKREEM (aptly named huh, you tend to want to scream when this thing screws up) is located behind the instrument cluster. There is a bunch o stuff that has to be removed (if I remember correctly) to access it. Also, isn't there a problem with having to have a proceedure done with a scan tool after it is replaced? Most of what I am offering here is a nagging feeling from reading a few too many posts a while ago. Good luck Vicki, if it is the SKREEM module I suspect you may need it.
In my book even the instrument cluster is under the dash.
