New owner of old car
Just bought a 04 CF has. bas/ESP light does not go out after the lock to lock reset. Also has a lamp out warning lamp all light on except tag lamp, could they trigger the warning lamp? I absolutely love the car 74000 miles I the 3rd owner clean car fax pulled the Dtc's get a po410 checked the relay looks okay blower activates if I manually operate the relay cleaned all electrical connectors applied dielectric to them pulled all fuses cleaned and dielectric grease sales fuse box cover some indication of prior moisture intrusion the prior po 730 was caused by me during test run accidently bumped auto stick into a lower gear under hard accel over revved cleared the code and it never showed back up. How do you test wheel speed sensor too expensive to just buy and try also may not be the problem, also the battery is a few years old, could be a voltage drop maybe?
Sorry for all the question just a little excited first move back to sports cars in 25 years, been doing the Harley thing , also tires? Eagles or Kuhmo's both avail in my area Very reasonable thanks all Karl
