Old Oct 24, 2012 | 11:11 PM
onehundred80
Default Re: Is it time for the VARTA battery to go?
Originally Posted by maxime75us
I discovered the wire set Magnecor is not holding on the spark plugs!!!!!! GEEZZZ
If you have any idea or have Magnecor wire set too. Please advise!
Thanks a lot
Max
It is possible that you are not pushing the connector down far enough, I had that with a set of new wires once. To check using a screwdriver or something see how far down the start of the connector is and check how far the plug will stick out. Then check to see if that is the extent that you have push it on.
