Is it time for the VARTA battery to go?
Old Oct 31, 2012 | 12:56 PM
maxime75us's Avatar
Default Re: Is it time for the VARTA battery to go?
Could it be the Oxygen Sensors?
Help!
THX!
Old Oct 31, 2012 | 01:42 PM
Mrmiata's Avatar
"might" not be your problem, but if your car has over 60K on miles, I'd think about getting a Bosch cps from Ebay. My car was throwing 02 sensor codes when I bought it. Would clear them with the OBD2 reader and within two weeks they were back. Car ran fine. CPS finally died and since replacing it (7 months now) the cel has not come back on.
Old Oct 31, 2012 | 06:52 PM
user 72983's Avatar
Banned
Ok, there might be other issues....
But, I've seen on many other threads in XFforum...post from the battery police...
The battery needs to be replaced, if it is the original...
Old Oct 31, 2012 | 11:24 PM
arejohn's Avatar
I would clear the codes to insure the 171 and 174 are the cause of the no start.
(P0171) FUEL SYSTEM 1/1
UNDERCORRECTION OF FUEL MIXTURE
(OFF IDLE). . . . . . . . . . . . . . . . . . . . . . . . . . 179
(P0171) FUEL SYSTEM 1/1 RICH CONTROL
OVER LIMIT (AT IDLE) . . . . . . . . . . . . . . . . . 183
OVER LIMIT (AT LOAD) . . . . . . . . . . . . . . . . 187
(P0174) FUEL SYSTEM 2/1 RICH CONTROL
OVER LIMIT (AT IDLE) . . . . . . . . . . . . . . . . . 218
OVER LIMIT (AT LOAD) . . . . . . . . . . . . . . . . 221
(P0174) FUEL SYSTEM 2/1 LEAN CONTROL
BELOW LIMIT (AT LOAD) . . . . . . . . . . . . . . . 224
(OFF IDLE). . . . . . . . . . . . . . . . . . . . . . . . . . 227
Old Oct 31, 2012 | 11:53 PM
If it is 171 and 174 codes I would suspect filter or pump failure. My guess would be pump failure with too little pressure and fuel at the injectors.
Get the fuel pressure tested.
Run too lean for too long and you could have bigger problems to solve. Engines are hard to start cold with a lean mixture.
The battery seems fine for now, the trouble with old batteries is that they can quit on you at the worst possible moment. I changed both my Vartas when they were working fine, but I did not want to be caught if one went dead suddenly on me. Stuck miles from anywhere you would pay dearly to have a new battery to put under the hood.
Old Nov 1, 2012 | 10:34 PM
maxime75us's Avatar
Last update!
Sometimes engine is knocking and the low headlight are not working anymore!
In case of it helps!
Old Nov 1, 2012 | 11:40 PM
maxime75us's Avatar
I have found a furl pump BOSCH on ebay. NEW for $64 instead of $170 to $500 on Advanced Autoparts! Insane
So Got a fuel Pump $60 BOSCH
CPS Wells $11.99
MAF $30
Not too bad when you go online to these auto stores. Only one part would be $150...INSANE
Hopefully it is going to take care of the problem. At least I will have new sensitive parts!
Will update soon!
northwest_crossfire
May 30, 2016 05:19 PM
BrenLW
Aug 5, 2015 04:53 AM
Rusty475
Jul 13, 2015 10:03 AM
cx24724
Jul 12, 2015 11:57 AM
FIXRE
Jul 9, 2015 09:16 PM
