Old Oct 25, 2012 | 11:55 PM
  #244 (permalink)
JHM2K's Avatar
JHM2K
Default Re: BEGi Turbo Kit information/discussion thread
Originally Posted by MrMoPar
Running an intercooler, if it is set at 8psi, will see 1-4 PSI in 1 and 2nd gear, and then ramp to 6-8 in 3rd and 4th gear. So the power is really going to come in around the 800 -1000 foot mark and pull really hard on the big end of the track. The turbo makes power based on load. Loading is low in 1st and second gear, plus the intercooler on a low boost system is actually detrimental to making boost. The turbo is trying to make power, but having to pressurize the intercooler space, while the cooling effect is actually lowering the boost pressure as the air density increases causing the air volume to contract.
The positive displacement supercharger is making significant boost right off the line and holding it through the run, so it is going to have the power advantage during the initial acceleration phase.
We saw this first-hand at the half-mile event in September... Many of the turbo cars were slow in the 1-2 start, but EXPLODED down the track once they settled into 3rd. If they were making serious power, they might be able to reel in the S/C'd cars, but that was a maybe.
GT-R was the exception, those things simply snacked on whatever they lined up against.
