Old Nov 1, 2012 | 10:41 AM
onehundred80
Default Re: Which sensor is this?
Originally Posted by alaxfire
Dave, you are both correct, and incorrect.
I was going by memory from when I examined the RCM that rayth sent me ( that I forwarded on to tighed1 ).
I wrote all the relay numbers down from that one, and it did in fact have a 5708 relay in the air pump location, while all the others were 5706 like you stated.
I just went out and removed my RCM, and you are correct there, they ALL are 5706.
BTW, did anyone ever figure out if we could order & replace these relays ?
If they had different relays in them we can rest assured that the RCM would have a different part number. That is the way the part numbering system goes, you change a part in the assembly and the whole assembly number HAS to change.
Therefore the RCM part number of the part with a 5708 relay in it would be different to the RCM part number with all 5706 relays in it. The same RCM part numbers means they have the same relays in them, that's DIN and ISO policy.
How to change a relay in the RCM.
