Old Nov 5, 2012 | 10:10 PM
rayth's Avatar
rayth
Default Re: Tail light issues...
The majority of problems in the rear lights, other than burnt out bulbs, are caused by using the wrong bulb.
If you have tried it with a bulb that you have SEEN work the problem lies in the socket or beyond.
Checking bulbs 101 dictates that you check the bulb for continuity, and check for power at the socket.
I am not sure how the contacts are in the bulb holder but sometimes the contact does not touch the bulb as it should because it is bent too far back or it has been burnt by sparking because of a bad contact for a while.
Thanks, I'll switch them around and see what I can find
