Tail light issues...
Old Sep 21, 2009 | 05:07 PM
TiffanyBabe's Avatar
Question Tail light issues...
Okay so I have an 04 Crossfire that has been having some tail light issues.... My right tail light doesn't seem to be working, but when I press on the break the light comes on. Is there certain fuses that may be needing to be changed? I changed the bulbs like 5 times thinking maybe I just kept getting bad bulbs but nope that wasn't it.... Any idea or info on this would be greatful, I would hate to get a ticket for no tail light. I have tried all I could do so now I am looking into what others think it may be. I would hate to go and have it looked at and fixed for a huge amount on money when I may just be able to fix it myself...
Thank you for your time ...
Tiff
Old Sep 21, 2009 | 09:39 PM
Moparrbust's Avatar
Default Re: Tail light issues...
By "not working" do you mean that the running light(s) aren't working? If so, when you changed the bulb 5 times did you make sure if the original and/or new bulbs were dual filimant? My only thought without seeing the car is that you put a single filimant bulb in place of a dual filimant. I've never pulled my taillight or changed any bulbs on my Crossfire so I can't confirm whether it's supposed to be dual filimant or not though.
Old Sep 21, 2009 | 09:58 PM
Yes those two circuits should be on different fuses. However if the tail light on the other side is working, then the fuse is not the problem. Are you sure you are using the correct bulb number? My next test would be to see if voltage is present at the socket with a 12v test light. It is possible you have a defective socket at that light. I replace headlight and taillight sockets weekly on our Ford vehicles in our fleet at work due to the sockets melting and causing a bad connection to the bulb.
James
Old Sep 21, 2009 | 10:05 PM
The book calls for a 21/5w which is a dual filament bulb. NAPA lists it as a LMP 17916. What are you using?
Are your bulb contacts the same as shown here?
James
Old Sep 21, 2009 | 10:31 PM
robby363's Avatar
Check fuse #7 in the fuse box that's located on the instrument panel on the driver's side behind the trim panel cover. It's a brown 7.5 amp fuse.
Old Sep 21, 2009 | 11:03 PM
WOW! There ARE two fuses, one for EACH taillight.
Check fuse 7 !!! If it's ok, make SURE you have the right bulb in there.
Beyond that, I would think it's a bad socket - but bad sockets are rare (well, common in boat trailers - rare otherwise).
Old Sep 23, 2009 | 10:56 PM
Whats the outcome? James
Old Sep 23, 2009 | 11:56 PM
Some how my hubby and I fixed it lol. We replaced the fuse just in case and switched the bulbs out again and it worked just fine... Thank you all for the help... Maybe my Crossfire was having hormonal issues lol...
Tiff
Old Sep 24, 2009 | 12:27 AM
tighed1's Avatar
Glad to see you got it fixed Tiff.
Man. Next time I have a problem I'm gonna sign in as a young female!
TONS of help!
Old Sep 24, 2009 | 09:42 PM
Moparrbust's Avatar
TONS of help!
That's always the case on every forum. lol
Old Oct 17, 2012 | 06:52 PM
rayth's Avatar
Hey guys, digging up an old thread but i am having the same issue with my right tail light.. the brake light works fine but the tail light is out.. Seems to have started after I replaced both tail lights when the left one was out, maybe i knocked something around? At any rate, I've replaced the bulb again to no avail and then I replaced fuse #7... it did look a little scorched but after replacing it, still no luck..
any suggestions on next steps to try?
Old Oct 30, 2012 | 10:21 PM
rayth's Avatar
anyone have any ideas?
Old Oct 30, 2012 | 11:59 PM
Simple check is to switch the bulbs, left to right and right to left, to see if the problem is bulb or socket related.
Old Oct 31, 2012 | 08:30 PM
rayth's Avatar
ive changed out the bulb already with no luck
Old Oct 31, 2012 | 10:22 PM
The majority of problems in the rear lights, other than burnt out bulbs, are caused by using the wrong bulb.
If you have tried it with a bulb that you have SEEN work the problem lies in the socket or beyond.
Checking bulbs 101 dictates that you check the bulb for continuity, and check for power at the socket.
I am not sure how the contacts are in the bulb holder but sometimes the contact does not touch the bulb as it should because it is bent too far back or it has been burnt by sparking because of a bad contact for a while.
Old Nov 5, 2012 | 10:10 PM
rayth's Avatar
Thanks, I'll switch them around and see what I can find
Old Nov 5, 2012 | 11:28 PM
AlexRMC92's Avatar
The illumination control module is another big issue that others (including myself have had). Are the front right parking lights and right side markers out too? Turn your lights on and hit the dash around the headlight switch with your hand and see if those lights flicker at all.
Old Nov 6, 2012 | 12:39 AM
rayth's Avatar
All the other lights work, including the brake so it seems to just be the connection to the tailight portion of the bulb... i'll give it a smack though just to see
Old Nov 6, 2012 | 10:23 AM
AlexRMC92's Avatar
The brake light is not on the same circuit as the tail light, but if the front right parking light and both right side markers work then the ICM is not your problem.
The right parking light, right tail light, and both right markers are on the same circuit. Same goes for the left side. So if the ICM is bad one whole side will go out except for headlights and brake lights.
I do believe each light has it's own ground wire so i would ensure that all grounds are connected properly. A volt meter across the socket contacts would help a lot.
Old Nov 13, 2012 | 09:38 PM
rayth's Avatar
problem solved: the contact tab for the taillight portion of the bulb was bent... easy fix!
