maxcichon
MikeR's and mine were to replace only the top arm.
MikeR also made small adjustable links to replace the sway bar connectors.
Are the Specialty Products bushings installed at both ends of the arms? This would 'splain it.
this is the Specialty Products 28840 description ( for Crossfire ) :
MERC C/E CLASS RR BSHGS 28840
These adjustable bushings make rear camber change possible for many Mercedes vehicles. By replacing the outer bushing in the two upper control arms, you achieve up to +/- 1.25 degree of change. Stock bushings are easily removed using the Specialty Products #75990 Bushing Press Adapters.
Rear Adjustment range: Camber +/- 1.25 degree
Installation time: .6 hr/side
Required 1 kit per wheel
